.Jack. Posted January 6, 2019 Share Posted January 6, 2019 Hi all Completely new to the forum however have browsed quite allot to search for answers! I have an electrical problem with my dash lights. The only lights that fail to come on are my: side lights, headlights and full beam dash lights everything else works fine. All lights work apart from those three. I've checked the earth and they seem fine, same as the fuses. Any advice would be massively appreciated. Jack Quote Link to comment Share on other sites More sharing options...
western Posted January 6, 2019 Share Posted January 6, 2019 Swap known working bulbs side/tail & dip headlights use the same green warning light switched by the main light switch on side of column [short stalk] main/full beam is the blue light switched by the indicator/dip/main beam stalk. could be a broken wire on the long stalk or a broken printed circuit on back of dash warning light panel Quote Link to comment Share on other sites More sharing options...
EeEk Posted January 6, 2019 Share Posted January 6, 2019 the lights that light up the speedo temp fuel ? They are on a switch down at the rh side of the dash. The interior light switch/dash light Quote Link to comment Share on other sites More sharing options...
western Posted January 6, 2019 Share Posted January 6, 2019 that switch only switches off the instrument lights not the warning lights Quote Link to comment Share on other sites More sharing options...
.Jack. Posted January 6, 2019 Author Share Posted January 6, 2019 Thanks for the replies, I've tried swapping bulbs but no joy. I think I'll check for any breaks within the printed circuit board. Quote Link to comment Share on other sites More sharing options...
