mcc1979ian Posted January 15, 2019 Share Posted January 15, 2019 Ok so iv just had a 300tdi rebuilt to replace the old knackered one, as far as I’m aware it got new timing kit, head gasket including head skim and new bolts, new turbo core, it’s got boost ring and pin and adjustable boost but now on cold startup this engine needs held to heat for a few seconds then once it fires up it miss’s as in sound like it runs on 3 cylinders. If you rev it you can often hear a couple o pops from the exhaust and plenty white/grey smoke, then all of a sudden it clears. What would all you knowledgeable chaps suggest? Quote Link to comment Share on other sites More sharing options...
Scotts90 Posted January 15, 2019 Share Posted January 15, 2019 Take it back to the place that rebuilt it? Were the injectors refurbed/tested at the rebuild stage? Could have a weeping injector... Quote Link to comment Share on other sites More sharing options...
TSD Posted January 16, 2019 Share Posted January 16, 2019 Hope I'm wrong but when I had those exact symptoms, it turned out to be a crack in the head between the coolant jacket and #1 intake(?) valve port. When sat overnight it bled a little coolant into #1 cylinder that took a few seconds to be dispersed on startup. It wasn't visible on inspection, but showed up on a pressure test. You could probably depressurise or even drain the coolant before the engine cools then see if it still misfires next day? Obviously running an engine with no coolant is a dumb thing to do, and even dumber if you tell your engine builder, and still expect them to sort it out for you afterwards Quote Link to comment Share on other sites More sharing options...
mcc1979ian Posted January 21, 2019 Author Share Posted January 21, 2019 She’s sounding very knocky and she’s taking a lot of cranking to pull the fuel through, I’m thinking possible injector or split in a fuel line Quote Link to comment Share on other sites More sharing options...
