Birdman96 Posted February 24, 2019 Share Posted February 24, 2019 I am replacing the injector loom again on a Disco 2 TD5 and trying to 'drain' some of the oil from the wiring to the red plug. I have pulled it back and left it disconnected from the ECU and hanging down the side of the engine. The red plug was full of oil but its not got into the ECU. I realise it won't drain all the oil out but some would be a help. I last changed the loom 4 years ago. Does anyone know how long I can leave the ECU disconnected from the battery without it loosing its programming? Quote Link to comment Share on other sites More sharing options...
BogMonster Posted February 24, 2019 Share Posted February 24, 2019 I don't think it is a problem - i.e. as long as you want. I don't think there is anything in the ECU, with the possible exception of fault codes, that requires power. Quote Link to comment Share on other sites More sharing options...
Ally V8 Posted February 24, 2019 Share Posted February 24, 2019 Bogmonster is right,you can disconnect it for as long as you want. Quote Link to comment Share on other sites More sharing options...
Birdman96 Posted February 24, 2019 Author Share Posted February 24, 2019 Thanks for that. Having left it hanging down quite a bit of oil has drained out through the plug! Quote Link to comment Share on other sites More sharing options...
