hurbie Posted March 23, 2019 Share Posted March 23, 2019 hello all , does anybody know what the numbers are for the 2 bearings inside a Warn M8000 winch , i need the bearing on the rear of the motor (behind the brushholder) and the bearing in the motor mounting plate next to the drum. also needed are 2 gaskets for the gearbox , are these only avelable from Warn ? greetings gerben Quote Link to comment Share on other sites More sharing options...
western Posted March 23, 2019 Share Posted March 23, 2019 Send a email with photo's of what parts you need to https://www.arbil.co.uk/4x4/shop/warn-winches/4x4-and-off-road/ they should be able to help you. if not try Devon4x4 https://www.devon4x4.com/off-road-store/winching/winch-spares.html Quote Link to comment Share on other sites More sharing options...
hurbie Posted March 23, 2019 Author Share Posted March 23, 2019 ok , had a bit of a clean , and the bearing on the shaft side of the motor is a 6203DL , so i can find that local . gasket is Warn 13848 so that is solved . now i only need the number for the bearing inside the motor , located under the brushholder. Quote Link to comment Share on other sites More sharing options...
hurbie Posted March 24, 2019 Author Share Posted March 24, 2019 messuring the remaining bits of bearing , it turns out to be a standard 6202 bearing . Quote Link to comment Share on other sites More sharing options...
western Posted March 24, 2019 Share Posted March 24, 2019 Glad you found the bearing part numbers, best wishes for obtaining new replacements. Quote Link to comment Share on other sites More sharing options...
