TD5 2003 fuel coolant leak
Sean.
Hello,
I've got a leak at one end of the fuel cooler on the TD5 2003. I've got the rubber gasket to replaxe it BS225. What I am having trouble with is how do I get the bracket off and back on again? The clip on the cooler, not the coolant pipe. I have the pipe clamp thing to get that off.
Thanks
One brand I know of is oetiker clip. Most of these style clips need a special tool to fit them as you crush a tab to clamp it on hence why they are only really single use. The factory would use an electronic tool to apply the same force to tighten the clamp.
Jubilee clips would work well as at least you know they are tight!
Steve
