hurbie Posted January 23, 2020 Share Posted January 23, 2020 hello all , does anybody know the right electrical diagram for my 1987 110 2.5NA , i have a landrover shopmanual , with a diagram for the wiring and switches , but these use a different color as i find in my car . the switch has a thick black/wit , thinner black/with and a green/red wire , also the voltage sensing relay has brown/white wires on it .... and the relay i think is for the rear screen has black/white , black , and white/red ..... also rather strangely the warning light panel has no integrated bulb for the screen heater (it's a bulbholder were you can put 2 little spade terminals on) all the diagrams i find use different colors 😞 thanks , gerben Quote Link to comment Share on other sites More sharing options...
simonb Posted January 23, 2020 Share Posted January 23, 2020 Black white is +ve feed to the element. Brown is battery perm live, white is an ignition switched live. White/red is starter solenoid - probably used by the relay to make sure the element isn't on when engine is cranking. What fault are you trying to fix? Quote Link to comment Share on other sites More sharing options...
hurbie Posted January 23, 2020 Author Share Posted January 23, 2020 i'm trying to fix the rear heated screen ( this has never worked , as long as i have the car 🙂 ) , so far i don't have power to the screen , there's power at the switch . and the switch is working. Quote Link to comment Share on other sites More sharing options...
