defender dinky Posted February 18, 2020 Share Posted February 18, 2020 Hi all, just installed ck3100 parrot hands free kit into my discovery 2, it was in my transit first then my defender all worked perfect, but in the discovery can't turn it down its deafening, although parrot is on its lowest, could it be coming through the amplifiers, if so is there something I need to had, can't see anything relating to this in the parrot ck3100 trouble shooting, as anyone else had this problem, dd Quote Link to comment Share on other sites More sharing options...
elbekko Posted February 18, 2020 Share Posted February 18, 2020 I had one that was installed in my P38 when I first got it. Couldn't deal with the unamplified output of the radio (which it plugged inbetween), so the startup beep was absolutely deafening. Don't think there's an easy way to fit it unless you can set it to not output an amplified signal? Quote Link to comment Share on other sites More sharing options...
