Harry m Posted April 2, 2020 Share Posted April 2, 2020 The horn as stopped working on the Defender 200 tdi I have traced the purple and black wire out and seem to have continuity from the connector at the back of the instrument panel to the horn but don’t seem to have power when I push the horn switch at the end of the stork I’ve checked the fuse all ok . Could it be a doggie switch? As anyone had this problem Quote Link to comment Share on other sites More sharing options...
western Posted April 2, 2020 Share Posted April 2, 2020 with a flat blade screwdriver pop the stalk end cap off, inside is a brass ring, a spring & the stalk has 2 brass fingers that contact the end caps ring, clean these up so they are bright/shiney then pop the cap on & see if it works, if nothing it could be a dead horn or a poor earth at horn end Quote Link to comment Share on other sites More sharing options...
Harry m Posted April 2, 2020 Author Share Posted April 2, 2020 Thanks will have a go tomorrow was wondering how it worked didn’t realise it popped off I will report back the result Quote Link to comment Share on other sites More sharing options...
western Posted April 2, 2020 Share Posted April 2, 2020 Put the flat blade in the gap & twist the end cap should pop off fairly easily. Quote Link to comment Share on other sites More sharing options...
Harry m Posted April 3, 2020 Author Share Posted April 3, 2020 All sorted now took the top off and cleaned the contacts also cleaned the earth contact on the horn it self all good now thanks for the help 1 Quote Link to comment Share on other sites More sharing options...
western Posted April 3, 2020 Share Posted April 3, 2020 A nice easy & no cost fix, always the best way. Quote Link to comment Share on other sites More sharing options...
