macclad Posted April 21, 2020 Share Posted April 21, 2020 Just had dash off to look at heater switch (another story) and noticed there is no wiring to my low oil light, where should it come from and what should i look for. Thanks Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted April 21, 2020 Share Posted April 21, 2020 Should be a white wire with a brown trace I believe, and it should go to the oil pressure switch on the engine. Quite impressed you've never noticed the oil light doesn't come on Quote Link to comment Share on other sites More sharing options...
macclad Posted April 23, 2020 Author Share Posted April 23, 2020 On 4/21/2020 at 3:49 PM, FridgeFreezer said: Should be a white wire with a brown trace I believe, and it should go to the oil pressure switch on the engine. Quite impressed you've never noticed the oil light doesn't come on Thanks, should it come on even if i have plenty oil in it. Quote Link to comment Share on other sites More sharing options...
Sigi_H Posted April 23, 2020 Share Posted April 23, 2020 It is not an oil level light, but an oil pressure light. No revs, no pressure => light on, when ignition on Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted April 23, 2020 Share Posted April 23, 2020 ^ As Sigi says, it should come on with the ignition ON and the engine OFF, once the engine starts it should go out. Quote Link to comment Share on other sites More sharing options...
