L19MUD Posted April 24, 2020 Share Posted April 24, 2020 I am struggling to work out what are the correct front steel brake pipes for my 200tdi 90 it's a late 200tdi so lots of bits are crossover - chassis number LA9333XX I know I could make them up but the steel ones lasted 25 years so they should do the job for me again if new. My 90 has rear discs and the brake valve which is bolted on the drivers footwell I need the drivers side front rigid pipe from this valve which runs along the chassis to the chassis bracket and into the flexi and the passenger side one which is the same but runs up and around the engine on the bulkhead Thanks Sam Quote Link to comment Share on other sites More sharing options...
western Posted April 24, 2020 Share Posted April 24, 2020 I think you would be better off making them from Kunifer brake pipe 3/16 diameter with M10 end fittings. just the left pipe ntc9726 on rimmer bros website is over 40 quid.you could repipe the complete vehicle for less than that. Quote Link to comment Share on other sites More sharing options...
L19MUD Posted April 24, 2020 Author Share Posted April 24, 2020 I know what a sensible person would do Western that is not me though I have found it for £5.95 plus vat at Britcar down the road from me and it will be a lot tidier than what I can bend.https://www.brit-car.co.uk/product.php/436552/0/pipe___brake what is the code for the other side please? 1 Quote Link to comment Share on other sites More sharing options...
L19MUD Posted April 24, 2020 Author Share Posted April 24, 2020 is it https://www.brit-car.co.uk/product.php/436447/3640/brake_pipe_cylinder_jump_hose_right_hand_defender ANR2503 for the right hand side? Quote Link to comment Share on other sites More sharing options...
western Posted April 24, 2020 Share Posted April 24, 2020 ANR2503 looks to be correct as far as I can tell. have you got the combination valve or does the pipes go direct from master cylinder to calipers. Quote Link to comment Share on other sites More sharing options...
L19MUD Posted April 24, 2020 Author Share Posted April 24, 2020 I have got the valve, the right hand pipe goes from the valve to the caliper. The left hand one goes from the master to the cylinder 1 Quote Link to comment Share on other sites More sharing options...
western Posted April 24, 2020 Share Posted April 24, 2020 Reckon those 2 pipes will get you sorted then. 1 Quote Link to comment Share on other sites More sharing options...
L19MUD Posted April 24, 2020 Author Share Posted April 24, 2020 Thank you. Last thing I need to fit before the front wings can go on and I can make it look like a land rover again 1 Quote Link to comment Share on other sites More sharing options...
L19MUD Posted April 25, 2020 Author Share Posted April 25, 2020 Anr2503 is roughly the right shape but is too long. It seems that was the pipe I bought incorrectly some time ago Quote Link to comment Share on other sites More sharing options...
western Posted April 25, 2020 Share Posted April 25, 2020 Just put a extra bend in Quote Link to comment Share on other sites More sharing options...
