Algerian110 Posted May 13, 2020 Share Posted May 13, 2020 I have a 1989 Land rover defender 110 that has a 2.5 NA diesel The guy that i bought it from didnt put a vacuum pump in it , i got a used one for a nice price The problem is that i installed the pump and it seems like its not turning , checked that the gear inside is rotating nicely with the camshaft driven but the pump is not turning i think there is a pin that drives the pump shaft with the gear on the block , and thats missing here ? If so , any dimensions for it ? so i can make it Note : i live in algeria , sadly i cant order any parts from the uk as customs holds everything Quote Link to comment Share on other sites More sharing options...
Snagger Posted May 14, 2020 Share Posted May 14, 2020 It’s hard to see in the photo, but there should be a pin across the bore of the skew gear, so yes, it appears that part is faulty. 1 Quote Link to comment Share on other sites More sharing options...
Algerian110 Posted May 14, 2020 Author Share Posted May 14, 2020 Thank u Snagger , yes it turned out im missing this piece included I just found a used engine that is no use , i hope i can find the skew gear to take it apart Quote Link to comment Share on other sites More sharing options...
Sigi_H Posted May 15, 2020 Share Posted May 15, 2020 if it is to difficult to get it, take an electric vacuum pump, like used in many cars on the scrapyard. Works perfect Quote Link to comment Share on other sites More sharing options...
Algerian110 Posted May 17, 2020 Author Share Posted May 17, 2020 Took the skew gear apart If i couldnt get it ill just get an electric pump , thank u guys Quote Link to comment Share on other sites More sharing options...
