Maverik Posted September 2, 2020 Author Share Posted September 2, 2020 22 minutes ago, Davidpaul said: Can I ask what turbo you used please, i have a vgt here but i haven't fitted it yet, was there much improvement low down ? Have a look at my build thread here https://forums.lr4x4.com/topic/49267-diamond-in-the-rough/page/33/#comments Quote Link to comment Share on other sites More sharing options...
Ex Member Posted September 2, 2020 Share Posted September 2, 2020 Without reading all of this, it might be covered. The stock oil separator closes off automatically when the intake pressure drops, so at high engine flow, it should close. Perhaps your valve was not working. FYI, the stock unit was made by Mann+Hummel. Quote Link to comment Share on other sites More sharing options...
Maverik Posted September 2, 2020 Author Share Posted September 2, 2020 3 hours ago, Red90 said: Without reading all of this, it might be covered. The stock oil separator closes off automatically when the intake pressure drops, so at high engine flow, it should close. Perhaps your valve was not working. FYI, the stock unit was made by Mann+Hummel. Hehe perhaps you should read the whole thread 😃 I (we) kinda came to the same conclusion. Didn't know the original was M&H good to know👍 Quote Link to comment Share on other sites More sharing options...
Callum200tdi Posted January 8, 2023 Share Posted January 8, 2023 On 8/11/2020 at 11:22 AM, Maverik said: On 8/7/2020 at 5:24 PM, Maverik said: The breather needs to be free flowing as much as possible, as its not designed for any kind of pressure, if you block it you know about it as pretty much every engine seal starts to blow oil out, done it once accidentally. So this is what I've done coiled a pieceof silicone hose up to make an orafice... see what happens... I done exactly the same to my 200tdi disco. I fibreglassed a 6mm to it and connected to my breather setup for wading as I have my turbo going straight to snorkel. The air filter on top before people say it’s no good to run no filter and haven’t blown a seal yet🤞. Quote Link to comment Share on other sites More sharing options...
