Glue Posted September 20, 2020 Share Posted September 20, 2020 Evening All, Can somebody confirm if PRC 6290 is the correct loom for my purposes: '99 Defender (VIN ends XA170xxx) with Rear Wash Wipe (Wash Bottle under the bonnet) and Heated Rear Window, NO High Level Brake Light. Wiper motor has the round, white 4 pin connector, as does the end of the loom behind the light cover. Many Thanks. Glue Quote Link to comment Share on other sites More sharing options...
western Posted September 20, 2020 Share Posted September 20, 2020 PRC6290 is correct for rear wash/wipe & heated rear screen with the circular connector meant for vehicles up to chassis LA939975. if you cannot obtain a genuine LR loom use this one https://www.autosparks.co.uk/lr479-land-rover-defender-90-110-rear-door-wiring-harness.html for that age of vehicle I would expect to see the later loom AMR3124 with the econoseal plugs Quote Link to comment Share on other sites More sharing options...
Glue Posted September 20, 2020 Author Share Posted September 20, 2020 Many Thanks Ralph, The mismatch between chassis numbers / corresponding part numbers and the age of the truck was throwing me. Part of the problem is that the truck went through SVO and a civilian contractor before spending 11 years with HM Armed Forces (RAF Mountain Rescue Sevice), being cast and spending a further 10 years with a selection of owners - its a bitsa and I love it. 1 Quote Link to comment Share on other sites More sharing options...
western Posted September 20, 2020 Share Posted September 20, 2020 Glad the info helps, if you know the military reg number enter it in here https://merlinarchive.uk/ & it should tell you what units/stations it served with Quote Link to comment Share on other sites More sharing options...
