Bigj66 Posted November 6, 2020 Share Posted November 6, 2020 Does anyone have a wiring diagram for the P38 Thor engine and fuse box they can point me towards? I think Rave only runs on Windows doesn’t it? I need the engine loom, starting circuit and fuel pump wiring if possible, cheers. Quote Link to comment Share on other sites More sharing options...
Bigj66 Posted November 6, 2020 Author Share Posted November 6, 2020 Apparently Rave does work on an iPad 👍 1 Quote Link to comment Share on other sites More sharing options...
Bigj66 Posted November 7, 2020 Author Share Posted November 7, 2020 Does anyone know how the evaporative emission canister purge valve system works on a P38 4.0 Thor engine? Is it some sort of pressure relief for the fuel tank? If the solenoid on the engine was to be disconnected from the loom then will the engine still run ok or will it cause problems for the ECU? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted November 7, 2020 Share Posted November 7, 2020 Yep, just disconnect it, twill be fine. 1 Quote Link to comment Share on other sites More sharing options...
Bigj66 Posted November 7, 2020 Author Share Posted November 7, 2020 1 minute ago, Bowie69 said: Yep, just disconnect it, twill be fine. No fault codes or limp modes? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted November 7, 2020 Share Posted November 7, 2020 You may get a fault code, but frankly who cares? Won't create a lump condition, no. 1 Quote Link to comment Share on other sites More sharing options...
Bigj66 Posted November 13, 2020 Author Share Posted November 13, 2020 Can anyone with a V8 Thor P38 identity this plug please? It’s located very close to the fuse box in the engine compartment and is connected by one blue/red wire to the pink multi plug on the underside of the fuse box. Rave suggests that it might be related to something called ‘ship disable’ 🤷♂️ Quote Link to comment Share on other sites More sharing options...
