Warning lights bottom left and top left on Defender 90 1996
yerba
So when driving at night I can see the top left and bottom left warning light very dimly lit (barely visible)  The lights indicator on the the switch are super bright however. Compare lights indicator with the dim warning lights Does this mean that the warning lights at the left corner are on or is it some glitch ? What are these warning lights anyway ?
Park brake should not be lit when driving, if it is then possible the internal wires of handbrake cable are seperating & causing the lever to not fully release.
Cab tilt light should not be lit at all, just remove the bulb holder, it's a left over from the proposed Llama truck which never got beyond test vehicles.
  • western changed the title to Warning lights bottom left and top left on Defender 90 1996
