Bigj66 Posted January 14, 2021 Share Posted January 14, 2021 Does anyone have a Series 3 in bits with the steering column exposed and can take some measurements for me? I need to find out the distance from the centre of the outer column clamp on the engine side of the bulkhead to the top of the outer column where the bearing sits. Then I need the distance the inner column sticks out of the outer column at the steering wheel end. Cheers. Quote Link to comment Share on other sites More sharing options...
Turnips Posted January 15, 2021 Share Posted January 15, 2021 @Bigj66 Are these the measurements you need? If they're not just let me know, the column and box are off the vehicle so easy to get to at the minute. Not sure if you meant the clamp right at the base or the one partway where it fastens to the bulkhead Quote Link to comment Share on other sites More sharing options...
Bigj66 Posted January 15, 2021 Author Share Posted January 15, 2021 11 minutes ago, Turnips said: @Bigj66 Are these the measurements you need? If they're not just let me know, the column and box are off the vehicle so easy to get to at the minute. Not sure if you meant the clamp right at the base or the one partway where it fastens to the bulkhead Absolutely bob on Sir, thank you very much 👍 Quote Link to comment Share on other sites More sharing options...
Turnips Posted January 15, 2021 Share Posted January 15, 2021 No problem, glad I could help you out. Your build thread is excellent by the way 👍 1 Quote Link to comment Share on other sites More sharing options...
