Uri77 Posted May 17, 2021 Share Posted May 17, 2021 Hello, I recently bought an LR (santana) 88 series 3 from 1978. it has a problem with the transmission. It makes a loud, dry noise, as if someone were hitting with a hammer. Noise appears according to speed. The faster the blows sound faster. When you go slow it doesn't make noise. I do not know exactly what it can be if the transfer case, gearbox, transmission shaft and crossovers, differential. I have done calculations and I believe that each time the blow is a wheel revolution. (more or less, 1-5 strokes per second, depending on speed) He does it in the 1-2-3-4 march. TRANSFER CASE: -In the short transfer it is only heard very slightly in 4th gear with the engine at full throttle. -With the long ones, he does it in all. When you go slow, no. It does so at 20km / h and the noise is progressive with speed. -With the neutral of the transfer and the engine at full throttle it does not make any noise. When you go fast (20-30km / h) with the clutch on it makes noise. If you tighten the clutch (20-30km / h) the noise disappears. This confuses me a lot because I thought it was the drive shaft and the cross braces. At first I thought it was the front differential and removed the front driveshaft. The noise seems to be from the front but, the truth with so little isolation, I don't know where it comes from. I am not ruling out the rear axle. I have it 300km from where I live and the next time I go I want to have some idea where to look. Can somebody help me. Thanks Quote Link to comment Share on other sites More sharing options...
Snagger Posted May 24, 2021 Share Posted May 24, 2021 Removing the front prop shaft (from transfer box to axle) will only eliminate that prop as a source. The front axle internal shafts and diff will still be turning at road wheel speed. The axle is a likely candidate from your description, possibly a broken tooth on the differential, or a bad bearing on a hub, shaft or diff. I’d check the wheels by jacking up the vehicle and feeling for wobbles and roughness of rotation before another test drive, just in case a wheel bearing is failing, but it could be as simple as a loose wheel. You could remove the drive flanges from the front hubs for a short test to see if it is a fault with the diff or half shafts and their bearings. It’d leak some oil, but shouldn’t do any harm over a short distance. Quote Link to comment Share on other sites More sharing options...
steve b Posted May 24, 2021 Share Posted May 24, 2021 Welcome to the forum It could be a loose planet pin in a diff hitting the pinion face once per wheel rev. ? It could also be the handbrake shoes loose or oil contaminated dragging on the drum maybe - but that usually only happens at slow speed or when slowing to a stop . 12 minutes ago, Snagger said: You could remove the drive flanges from the front hubs for a short test to see if it is a fault with the diff or half shafts and their bearings. It’d leak some oil, but shouldn’t do any harm over a short distance. If it still does it then replace front drive flanges and remove the rear propshaft and try it in 4x4 high , if it still does it remove the rear drive flanges and halfshafts and try it again Steve Quote Link to comment Share on other sites More sharing options...
