Escape Posted June 11, 2021 Share Posted June 11, 2021 For a late RRC, the brackets that support the brake hoses where they join the pipes on the inner wheel arch. I've found the lower brackets, on the swivel balls (FTC1362 and FTC1363). But no trace of the upper ones in microcat or parts.jaguarlandroverclassic.com. Maybe they're not available separately? The wheel arches have been repaired, the brackets are missing. Which makes it hard to properly route and support the brake lines. Thanks! Filip Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted June 11, 2021 Share Posted June 11, 2021 This one? https://yrmit.co.uk/product/inner-wing-brake-pipe-bracket-part-f-land-rover-discovery-1range-rover-classic/ Not sure if available from the usual suspects. 1 Quote Link to comment Share on other sites More sharing options...
Escape Posted June 12, 2021 Author Share Posted June 12, 2021 Yep, that looks about right! I should have known to look at YRM. Though I'm not sure if they're welded or bolted on the later RRC. Pipes are routed differently, behind the spring mount to allow for the damper at the front when EAS is fitted. Thanks again! Filip 1 Quote Link to comment Share on other sites More sharing options...
