pinny Posted January 21, 2007 Share Posted January 21, 2007 the wastegate on my 300tdi appears to do nothing i checked pipe from injector pump to gate valve no leaks should this valve move when the engine is running idle and fast speed if it aint working will vehicle still run smoothly or run sick if i blow down pipe there is no resistance should there be and should gate move help please can this be replaced as it is a seperate to turbo Quote Link to comment Share on other sites More sharing options...
Andy Posted January 21, 2007 Share Posted January 21, 2007 you wont see the wastegate move unless the engine is underload. the pipe that goes to the injection pump also goes to the output side of the turbo, so you will be able to blow down it with no resistance. when the turbo pressure builds the pressure in that pipe does two things, one it pushes the diaphram down in the injection pump increasing fueling & two it presses on a sprung loaded diaphram in the wastegate actuator. when the pressure in the turbo exceeds the spring loading in the actuator (which is adjustable on the threaded rod that runs off it) the wastegate opens dumping the excess gas. you'd know if your wastegate didnt work cause your engine would either never get on boost & be VERY slow if it was stuck open or your engine will go like s*** off a shovel for a little while then explode if its stuck shut. the only real way to test them i know of is to connect a boost gauge, if your engine holds the correct boost then the wastegate is working correctly. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted January 22, 2007 Share Posted January 22, 2007 just out of interest what peak boost pressure does a turbot get to if you weld the wastegate shut? Quote Link to comment Share on other sites More sharing options...
white90 Posted January 22, 2007 Share Posted January 22, 2007 well with the waste gate tube perished I was seeing over 2bar and climbing the 90 was going well when I noticed the boost gauge showing the alarming sight! Quote Link to comment Share on other sites More sharing options...
pinny Posted January 22, 2007 Author Share Posted January 22, 2007 ooh well it must be ok it pulls ok and hasnt gone bang yet thanks guys Quote Link to comment Share on other sites More sharing options...
Andy Posted January 23, 2007 Share Posted January 23, 2007 i drove a volvo 440 turbo with a seized shut wastegate once, it'd spin the wheels by just flooring it in 3rd at about 30mph & leave a T5 for dust. not sure how long it lasted after the garage i worked for sold it to a trader though. Quote Link to comment Share on other sites More sharing options...
