pgrbff Posted March 25, 2022 Share Posted March 25, 2022 96 300Tdi hicap, SALLDHHF7TA975470 The transfer case is leaking at joint with front propshaft. As I will be ordering the parts from the UK, and want to make sure I have everything I need, can someone help? Do I order just the oil seal and the bearing, just in case, or might I need the sealing washer, mudshield, circlip or spacer? Quote Link to comment Share on other sites More sharing options...
miketomcat Posted March 25, 2022 Share Posted March 25, 2022 The mud sheild is a good idea as they can come loose. The felt washer (#2) and a new nyloc are also worth it. I wouldn't bother with the circlip or spacer. Mike Quote Link to comment Share on other sites More sharing options...
pgrbff Posted March 25, 2022 Author Share Posted March 25, 2022 Many thanks Quote Link to comment Share on other sites More sharing options...
pgrbff Posted March 25, 2022 Author Share Posted March 25, 2022 Using the parts book from this link http://www.retroanaconda.com/landrover/2010/02/land-rover-defender-110-parts-book/ , which Western kindly gave me, I can only find drawings for the transfer box to front flange for the LT77 and the LT85. The parts appear identical for both boxes. I have an R380 gearbox, will the parts be the same? I'm sure I'm being thick here. Quote Link to comment Share on other sites More sharing options...
western Posted March 25, 2022 Share Posted March 25, 2022 Rear output flange & associated parts on page 369 of the transfer box pages, LT77 & R380 use the same parts as both are on the transfer box. Quote Link to comment Share on other sites More sharing options...
pgrbff Posted March 26, 2022 Author Share Posted March 26, 2022 Thanks again 1 Quote Link to comment Share on other sites More sharing options...
