Cornish Rattler Posted April 8, 2022 Share Posted April 8, 2022 (edited) Hi guys I struggle to see the fuel gauge at night ( S2a ) as even with the gauge lite up its very dim during the day its fine, can i buy a brighter bulb for the fuel gauge or am i better off buying an old school 52mm round gauge and fitting it somewhere on the dash please. Edited April 8, 2022 by Cornish Rattler Quote Link to comment Share on other sites More sharing options...
Snagger Posted April 8, 2022 Share Posted April 8, 2022 Yep, should be easy to fit a brighter bulb or an LED. If you do go with LED, try to find “warm white” as most are a little bit bluish. Probably a good idea to replace the speedo’s bulb with the same so that they match. I’d also have a look at the wiring and bulb holder, as they could be a bit damaged or corroded and be causing a voltage drop - swapping the speedo and cluster gauge bulbs and holders from one to the other would be a simple stet of that. Quote Link to comment Share on other sites More sharing options...
Cornish Rattler Posted April 8, 2022 Author Share Posted April 8, 2022 16 minutes ago, Snagger said: Yep, should be easy to fit a brighter bulb or an LED. If you do go with LED, try to find “warm white” as most are a little bit bluish. Probably a good idea to replace the speedo’s bulb with the same so that they match. I’d also have a look at the wiring and bulb holder, as they could be a bit damaged or corroded and be causing a voltage drop - swapping the speedo and cluster gauge bulbs and holders from one to the other would be a simple stet of that. Thanks for that but i've just remembered its an S2a with S3 gauges fitted ☹️ Quote Link to comment Share on other sites More sharing options...
Snagger Posted April 10, 2022 Share Posted April 10, 2022 The gauge construction is the same and both can have the same faults and both can be retrofit with LEDs, easier if you also buy the capless holders. Quote Link to comment Share on other sites More sharing options...
Cornish Rattler Posted April 10, 2022 Author Share Posted April 10, 2022 15 hours ago, Snagger said: The gauge construction is the same and both can have the same faults and both can be retrofit with LEDs, easier if you also buy the capless holders. Thanks Snagger i will look into that 👍 1 Quote Link to comment Share on other sites More sharing options...
