Wont start - TD4 auto
JCB
Turn the key and it clunks - does not start :angry: . I suggest its the starter motor.
Battery seems fine - tried to jump start it - no difference.
Any ideas?
Also, recently (when it started fine) it seems to vibrate a little at idle - you can feel it through the brake pedal. Also, if you rev it whilst in Neutral and let it go back to idle it hunts a bit (almost dies). Any ideas?
Thank.
Solenoid on the starter motor I should think. Try biffing it with a hammer (if you can even see it on a Td4? possibly not) otherwise being a newish LR I doubt you can get any bits apart from a complete starter motor. Console yourself with the fact the Td4 starters are not nearly as unreliable as Td5 and TDv6 ones...
