JCB Posted January 23, 2007 Share Posted January 23, 2007 Turn the key and it clunks - does not start . I suggest its the starter motor. Battery seems fine - tried to jump start it - no difference. Any ideas? Also, recently (when it started fine) it seems to vibrate a little at idle - you can feel it through the brake pedal. Also, if you rev it whilst in Neutral and let it go back to idle it hunts a bit (almost dies). Any ideas? Thank. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted January 24, 2007 Share Posted January 24, 2007 Solenoid on the starter motor I should think. Try biffing it with a hammer (if you can even see it on a Td4? possibly not) otherwise being a newish LR I doubt you can get any bits apart from a complete starter motor. Console yourself with the fact the Td4 starters are not nearly as unreliable as Td5 and TDv6 ones... Quote Link to comment Share on other sites More sharing options...
DEANO3528 Posted January 24, 2007 Share Posted January 24, 2007 Console yourself with the fact the Td4 starters are not nearly as unreliable as Td5 and TDv6 ones... Except for JCB's of course. Quote Link to comment Share on other sites More sharing options...
