petrolhead63 Posted August 5, 2022 Share Posted August 5, 2022 Headliner out to recover, leaks to fix and dodgy wiring due to damp. Sunroof, roof rails to re seal. One sunroof drain snapped off explaining most of the water! have ordered repair parts. I notice gaps under the sunroof frames to roof panel, I could simply mask and PU seal around each frame but wonder if I slacked all the mounting bolts can I pry the fame up a little to squeeze sealer under it before tightening back down? Thanks. 1 Quote Link to comment Share on other sites More sharing options...
DiscoHere Posted October 25, 2022 Share Posted October 25, 2022 Yes you can but not sure it will last. I just tightened mine down on the rubber and added extra drain outlets at the rear of the sunroof and fed them out the rear of the vehicle. Not had a leak that i have noticed since Quote Link to comment Share on other sites More sharing options...
teabag Posted October 26, 2022 Share Posted October 26, 2022 18 hours ago, DiscoHere said: Yes you can but not sure it will last. I just tightened mine down on the rubber and added extra drain outlets at the rear of the sunroof and fed them out the rear of the vehicle. Not had a leak that i have noticed since If water is getting into the drain channels, thats if your lucky as they are only positioned at the front of the sunroof, then your vehicle a faulty class seal, simples. But there’s also a frame to roof seal that is well known to have issues and then water will go straight onto the headliner. The drains are only to take water runoff, if wet when the glass is tilted, hence positioned at the front only. Quote Link to comment Share on other sites More sharing options...
