David73 Posted October 8, 2022 Share Posted October 8, 2022 (edited) My land Rover TDI 300 blows a lot of smoke out of the oil filler under idle is this normal Edited October 8, 2022 by David73 Smoking Ronda Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted October 8, 2022 Share Posted October 8, 2022 No, definitely not, known as excessive crankcase pressure. Lots of causes, but to start with is knackered filler cap, blocked breathers, head gasket failure, knackered piston rings or cracked piston. How does it run otherwise? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted October 8, 2022 Share Posted October 8, 2022 To add, do you mean when the cap is on or off? If off, then totally normal, on, you have a problem. Quote Link to comment Share on other sites More sharing options...
Blanco Posted October 8, 2022 Share Posted October 8, 2022 It's very tempting to say that it is quite normal,.... at least not unusual,... but it is an indication that trouble is brewing. If you are new to 300 Tdi motors then you could do worse than flick through a few of the Brittania Restorations videos (youtube) on the Spanish 110, he had a newly reassembled engine blowing oil out and goes through most possible causes, first thing to do though is check and clean the breather. Quote Link to comment Share on other sites More sharing options...
