Green200tdi Posted November 19, 2022 Share Posted November 19, 2022 Hi all just a quick one, td5 rear light loom is the rear wiper and rear heated window in this loom or has it a separate loom that goes through the head lining? Thank you. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted November 19, 2022 Share Posted November 19, 2022 The wiring for all the bits on the door - so the rear wiper, heated window and high-level brake light - is part of the chassis loom yes. There is a multiplug in with the rear lights on the drivers side, where the rear door loom plugs in. Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted November 19, 2022 Author Share Posted November 19, 2022 2 hours ago, Retroanaconda said: The wiring for all the bits on the door - so the rear wiper, heated window and high-level brake light - is part of the chassis loom yes. There is a multiplug in with the rear lights on the drivers side, where the rear door loom plugs in. Ok thank you I brought another loom (td5) for my old 110 about 4 years ago now so guessing it’s a van loom can’t see any connections for rear door, yes I’ve gone from front to back in side fuse box it’s all td5 now as old 110 loom was stuffed 😊 Quote Link to comment Share on other sites More sharing options...
Ibex94 Posted November 22, 2022 Share Posted November 22, 2022 The connector should be behind the offside rear light cover panel. It should be an econoseal connector and you can get spare components for these from www.simtekuk.co.uk. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted November 22, 2022 Share Posted November 22, 2022 See here: https://www.lrworkshop.com/connectors/defender-2002my/C0704 Should be in all chassis looms except those for pickups, although I suspect even many of those still have them laying unused behind the cover. Quote Link to comment Share on other sites More sharing options...
