gtss- Posted February 1, 2023 Share Posted February 1, 2023 Hello, I am planning to order a new 2023 Defender 110 base model, specifically from Japan. Does anyone know whether or not I will get the premium LED headlights with the signature ring DRL? Because I'm after the signature DRL LED. Thanks. Quote Link to comment Share on other sites More sharing options...
Chicken Drumstick Posted February 1, 2023 Share Posted February 1, 2023 Probably best to get confirmation from the dealer you are ordering from. I know in the UK at least, specs can change after you order and has been quite frequent in the past couple of years on the Defender. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted February 1, 2023 Share Posted February 1, 2023 Your dealer will be able to tell you, plus it will be listed on the specification. My understanding however is that the base model does not come with the premium LED lights, you may be able to specify them as an upgrade option. However I also understood that the base model had been discontinued, and the lowest spec available was the SE, which does include the premium LED headlights. It is still available in the hardtop variant though. Quote Link to comment Share on other sites More sharing options...
