Snagger Posted March 24, 2023 Share Posted March 24, 2023 Hi folks. Can anyone please help with part numbers for the pipes/hoses to connect the oil stat housing on the side of an R380 with the oil cooler on a 300Tdi RRC. Searches online suggest that the oil cooler is not the big-brush type but a finned type like the coolers on P38 and DII, but I am not certain about that. If anyone has a good set laying about, then that would be an option rather than brand new. Thanks Quote Link to comment Share on other sites More sharing options...
western Posted March 24, 2023 Share Posted March 24, 2023 this is a 300tdi Auto trans gearbox oil cooler [not engine] https://britcar.com/product.php/198064/0/oil_cooler_auto_box_300tdi_disco Quote Link to comment Share on other sites More sharing options...
Snagger Posted March 24, 2023 Author Share Posted March 24, 2023 It is a gear box cooler I want. I have the oil stat assembly, but not the piping it cooler. I have seen both the cylindrical and finned coolers listed for that generation of vehicle (I had been concerned that MTF94 may be a bit viscous for a finned type). I can only find parts for ZFs, not R380, though. Quote Link to comment Share on other sites More sharing options...
western Posted March 24, 2023 Share Posted March 24, 2023 Sorry, misread it as engine, IIRC the actual oil cooler for the R380 is just a rigid pipe across the front of the engine bay. Quote Link to comment Share on other sites More sharing options...
western Posted March 24, 2023 Share Posted March 24, 2023 I've ditched the previous incorrect diagrams, on LRCAT this is the R380 gearbox oil cooler & pipes & shown on Brit-car site. looks to be the same as Auto box cooler. if you go to this page & click on the pipe item number it should/will show it below the diagram. https://new.lrcat.com/#!/1229/85911/86156/6777/86331 Quote Link to comment Share on other sites More sharing options...
Snagger Posted March 24, 2023 Author Share Posted March 24, 2023 Thanks, Ralph. I’m not familiar with the pipe arrangement for the ZF, so don’t know if the unions are the same threads and locations as for the R380. Is that what you understand the diagrams to say? I understand that the Defender uses a plain metal tube for the cooler, but was under the impression that the RRC and Discovery used a proper cooler. I think I will fit the later ZF finned type - my VIN is a MA rather than KA, so the bog brush is probably incorrect for the year. I think the finned type are a bit cheaper, too. I suppose the pipes can always be adapted with some unions and hose to fit the oil stat housing, if need be. 1 Quote Link to comment Share on other sites More sharing options...
western Posted March 24, 2023 Share Posted March 24, 2023 Thse are ZF oil cooler parts, click item number for part number to show I don't know what the connections threads are or if they are same/different from the R380 parts. https://new.lrcat.com/#!/1229/85911/86383/6791 https://new.lrcat.com/#!/1229/85911/86383/6792 https://new.lrcat.com/#!/1229/85911/86383/6793 Quote Link to comment Share on other sites More sharing options...
Snagger Posted March 25, 2023 Author Share Posted March 25, 2023 Thanks, Ralph. Managed to work out the parts and even find from some links that came up the correct hoses for the LT77 or R380 (ESR2808 and ESR2809, the other parts are the same as for the ZF). Order made. Quote Link to comment Share on other sites More sharing options...
western Posted March 25, 2023 Share Posted March 25, 2023 Pleased you managed to sort out what you need. 1 Quote Link to comment Share on other sites More sharing options...
Snagger Posted March 28, 2023 Author Share Posted March 28, 2023 For those interested in doing the same, the bulk of the parts are the same as for the automatics, but the 300Tdi models used a finned cooler, like a slim normal rad, and the manuals have different pipes from the oil stat housing to cooler, ESR2808 and 2809. 2808 is no longer available, but 2809 seems to be easy to find. Also NLA are the brackets to attach the cooler to the body shell or chassis. The diagram below shows the automatic and manual transmission versions, the manual pipes being the longer ones at the bottom of the diagram - parts 4 and 6 are the front ends of those pipes to the flexible hose sections, and the bottom parts are the rear ends, but they come as swage jointed complete pipe assemblies. Quote Link to comment Share on other sites More sharing options...
