Archie Storey Posted April 1, 2023 Share Posted April 1, 2023 (edited) hello everyone need some help!! i have a 2001 land rover defender TD5 it has issues starting i have it at my local garage and they dont know what it is they have replaced a load of parts and have got it down to... you turn the key and it does not turn over the engine and does nothing but when you spray quick start spray into the air intakes and then turn the key it fires straight up. what is the issues please help! when you turn the key the car turns over but does not startthey have replaced the pumpit only starts when you spray quick spray in the air intakes Edited April 1, 2023 by western Title made more relevant to post content Quote Link to comment Share on other sites More sharing options...
Hazza Posted April 1, 2023 Share Posted April 1, 2023 Once it starts on spray - does it then keep running? Or does it die once the spray is taken away? Quote Link to comment Share on other sites More sharing options...
fmmv Posted April 1, 2023 Share Posted April 1, 2023 (edited) So are you saying it only turns over if quick start is sprayed? One possible thing is the starter solenoid contacts wear out on td5s, and cause the starter to stop working. If you tap the starter it can sometimes make it work for a bit. New contact kits are fairly cheap and easy to fit if it is this; check ebay. Edited April 1, 2023 by fmmv Quote Link to comment Share on other sites More sharing options...
Archie Storey Posted April 2, 2023 Author Share Posted April 2, 2023 it keeps running thank you i will tell my garage about the starter soleniod yes it only turns over if quick start is sprayed Quote Link to comment Share on other sites More sharing options...
Hazza Posted April 3, 2023 Share Posted April 3, 2023 Only turning over with quick start is extremely odd - can't understand how or why that would happen. It must turn over when the ignition is turned but theres no quick start too? Based on this assumption, sometimes the starter motors start to break down, causing electrical interference which affects the crank position sensor. You can test this by turning ignition on and then bump or tow starting. I.e. starting the engine without the starter motor interference. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted April 3, 2023 Share Posted April 3, 2023 I suspect he means it only starts if easy start is sprayed in while turning it over. Without easy start it will just turn over but not fire up. Quote Link to comment Share on other sites More sharing options...
