defender dinky Posted July 7, 2023 Share Posted July 7, 2023 Hi all, is kick down cable the correct term for it, as I can't find anything in the haines for it, I need to know the correct way to adjust it, as the truck gets to 2000 revs then goes flat and struggles up hills, just trying things atm, its a range rover classic 3.5 v8 auto 1988/89, dd Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted July 7, 2023 Share Posted July 7, 2023 There's normally a crimp on the cable, adjust the cable so there is ~3mm gap between it and the threaded outer sheath of the cable. This assuming it is on EFI. Carbs setup I know nothing about! I'm not certain that's your problem, however, but give it a try. Quote Link to comment Share on other sites More sharing options...
defender dinky Posted July 7, 2023 Author Share Posted July 7, 2023 Quick reply thanks dd Quote Link to comment Share on other sites More sharing options...
