1996 110 gutter
Hi, new to defenders. Just addressing some work on mine and adjusting the roof for at the front edge at is doesn’t sit correctly.
I noticed the gutter full of a sealant/filler of quite some thickness, painted but cracking all over. Am now removing all.
I assume these had a run of sealer along them from new and should I be look in g to smooth the channels out again or just a run along any panel joins?
Ive looked at several video posts etc but can’t determine this.
Thanks and apologies to those who maybe are bored of this subject 😬
I did exactly this job a few years ago on my 1994 vehicle as the sealant was cracking and splitting in lots of places. It was definitely a factory thing, and a pig to get off, so you’ve done well.
I more or less replicated what was there using broad beads of white PU sealant and smoothing them down. Ended up not too bad and although water always gets in, I’m sure it’s not through the guttering any more.
