western Posted September 8, 2023 Share Posted September 8, 2023 Thinking about replacing my steel fuel tank because it's weeping from bottom face, with a Td5 plastic tank, my galvanised Marsland chassis has the brackets for it as far as I can tell. Is this change feasable? I don't mind if the filler neck has to be change, but will I need the Td5 pick up pipe or can I keep the current side sender/pickup pipe? Quote Link to comment Share on other sites More sharing options...
Eightpot Posted September 8, 2023 Share Posted September 8, 2023 The TD5 rear crossmember is different to the earlier style - it has a different profile on the back of the crossmember which is slimmer than earlier ones - the td5 tank only just fits in the space- If marsland have used the td5 crossmember on yours and fitted the brackets then no problem but if not, it will not fit (I've tried!) TD5 tanks have only a large hole on the top for the combined pump/level fuel & return unit - you can't add a side sender. Hope that helps Quote Link to comment Share on other sites More sharing options...
fmmv Posted September 9, 2023 Share Posted September 9, 2023 (edited) The Puma tanks will have the correct fuel pump, ie not a pump, like ROW 300s rather than td5, if you are getting a used one. As far as I know the tanks are the same. Or Safari used to make stainless tanks... Edited September 9, 2023 by fmmv Quote Link to comment Share on other sites More sharing options...
western Posted September 9, 2023 Author Share Posted September 9, 2023 Yes to having the Td5 rear cross member, Thanks I may go for a stainless tank. Quote Link to comment Share on other sites More sharing options...
