Green200tdi Posted November 19, 2023 Share Posted November 19, 2023 (edited) Strange one, I was lead to believe when I brought my loom that it was a 15p loom but now I’m not so sure,🤔 I was playing with the under seat fuse box tonight, need to hook up the glow plug live on the lid it says side lights 30 amp and that the glow plugs are 100 amp when I removed the 100 fuse all the side light went out so guess it’s the wrong lid on the fuse box or I have a different loom to the lid? also should I swap the 100 amp to the 30 amp if that’s the side lights? Edited November 19, 2023 by Green200tdi Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted November 19, 2023 Share Posted November 19, 2023 Someone has been messing about, all the smaller fuses are 10s, not what it says on the cover they should be. I can't read what rating the blue one is, is that the 100A? Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted November 19, 2023 Author Share Posted November 19, 2023 5 hours ago, Bowie69 said: Someone has been messing about, all the smaller fuses are 10s, not what it says on the cover they should be. I can't read what rating the blue one is, is that the 100A? No that’s me I’ve been using the other fuses for (dad got a fuse mines blown) lol when the loom was hanging around in the garage I have a pic of what I need I’ll go get new ones soon, yes the blue one is 100amp but it’s also the side lights, 🤔 was trying to work out what one is the glow plugs and connect my ones up. Quote Link to comment Share on other sites More sharing options...
toenden Posted November 19, 2023 Share Posted November 19, 2023 The glowplugs goes to the other terminal with a screw. If you se closely you should be able to follow the metal in the plastic. Comming to think of it, if you connected the live wire to the wrong one, you will be feeding all the other fuses reverse and the will "go out" when the 100A fuse is removed... sure it mounted is the right way around? 🙂 /mads Quote Link to comment Share on other sites More sharing options...
