Electricity - switch that combines 2 on/off switches
For switching between maps on my td5 I am looking for a turnable switch with 4 positions that can replace 2 off/on switches but without working with diodes or so.
I need:
off/off = standard map
off/on = road fast
on/off = offroad
on/on = 1500 rpm for winching
Current switch I use has 4 positions but I can use only 3 of them
Do the switches have to be isolated, or can they be common at one side? And is it just low current inputs to an ECU?
If it's something like
A Open B Open
A Ground B Open
A Open B Ground
A Ground  B Ground
Then you might be able to find a BCD switch and just use the lowest 2 bits.
Something like https://uk.rs-online.com/web/p/pushwheel-switches/0334123 would work. It would just repeat 0-3, 4-7, 8-9.
There used to be wafer switch kits for building rotaries in any combo that was wanted, but I've not seen them for years.
If you like the pushwheel, I could probably find one or two for you to play with.
That is more the solution I am looking for!
Thanks for the help
I now use a 4 position double pole switch but it is limited to 3 possibilities (off-off, on-off, off-on), the on-on is not possible just like that
