muddyplugger Posted March 5, 2007 Share Posted March 5, 2007 In a nutshell, I have had the front faulty ABS wheel sensor and hub replaced to banish those damn lights. However (isn't there always an However!), however now the 3 amigos are intermittent, which is better than it was (passed its MOT), but my local Independant chap has tried all to extinguish the lights with various purging codes to God knows what other buttons LR RAVE system has. It transpires that the ABS modulator is the fellow causing the intermittent fault; so I can buy a 'repair kit', which is not guaranteed to work, or splash out for a new/recon modulator! The former still is a few hundred quid all in, and the latter is running to more hundreds of quids! Any one any experience of this?? I suspect every SeriesII Disco owner has been here! Thanks. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted March 5, 2007 Share Posted March 5, 2007 Mine flips every time if you give it a lot of LH lock and boot the throttle hard on loose gravel. Rest of the time, it behaves. I do know of a couple with similar problems here though, and we can't figure it out either One of many reasons I hate electronics. How often does an air locker throw up three bongs and a warning light when you weren't even using it? Quote Link to comment Share on other sites More sharing options...
ChrisV8 Posted March 6, 2007 Share Posted March 6, 2007 Just a thought have a look on www.bba-reman.com these guys rebuild ABS units and have a good diagnostics and problems page for LR and lots of others in the web site. Quote Link to comment Share on other sites More sharing options...
muddyplugger Posted March 7, 2007 Author Share Posted March 7, 2007 Thanks chaps! Quote Link to comment Share on other sites More sharing options...
