rejo Posted March 28, 2007 Share Posted March 28, 2007 Anyone using these on a series I disco, if so what numbers are you using and what lift did you get. Thanks Jo Quote Link to comment Share on other sites More sharing options...
tpk241 Posted March 29, 2007 Share Posted March 29, 2007 Yer, Got these on my disco .. best people to speak to are devon4x4 phone them and give them the rundown on your disco and they'll suggest a mixed kit to suit the load. I have a stripped out commercial which i got 764’s on the front with 763’s in the rear .. hard ride .. but great off-road .. i run with no rollbars etc and i have less body roll than my mates standard. Gives a 2.5 inch lift .. and a level one at that .. the back is nice and high .. May cause driveline vibes and the usual suspects though as exceeds 2" Quality kit, go for it and spend a bit more on OME, its worth it .. TPK Quote Link to comment Share on other sites More sharing options...
andyb Posted March 29, 2007 Share Posted March 29, 2007 I have a stripped out commercial which i got 764’s on the front with 763’s in the rear .. hard ride .. but great off-road .. Same spring setup as me. I have a stripped out 3dr with a winch on the front and an internal cage. Would say that the ride is firm rather than hard, but then there maybe a slight weight difference between commercial and normal 3-dr. Cost me in the region of £500, but has proven to be money well spend. They have been fitted for about 5 years now and are truelly 'fit and forget' HTH Quote Link to comment Share on other sites More sharing options...
