gsr341 Posted April 4, 2007 Share Posted April 4, 2007 hello guys bought an ARB locker a while back (second hand) getting ready to sort it , would i be right be right in thinking the flexi pipe from compressor to the locker id 3/16" ? cheers Quote Link to comment Share on other sites More sharing options...
bishbosh Posted April 4, 2007 Share Posted April 4, 2007 No - IIRC it is 5mm which you will find is an odd size in the air line industry. At least I did when I was looking for push fit connectors. Found some eventually HERE Quote Link to comment Share on other sites More sharing options...
Tonk Posted April 4, 2007 Share Posted April 4, 2007 Hyphose also do metric 5mm fittings, the copper tube inside the diff is 3/16 iirc Quote Link to comment Share on other sites More sharing options...
gsr341 Posted April 4, 2007 Author Share Posted April 4, 2007 cheers for that boys , i must have the wrong fitting kit (wqas told there where diffrent ones ) thought 3/16" was a bit puney Quote Link to comment Share on other sites More sharing options...
istruggle2gate11 Posted April 4, 2007 Share Posted April 4, 2007 cheers for that boys , i must have the wrong fitting kit (wqas told there where diffrent ones )thought 3/16" was a bit puney I converted from the 3/16" copper to 6mm nylon, using a little bulk head adaptor from my local compressor man, keeps things simple and easy to source. Quote Link to comment Share on other sites More sharing options...
