Les Brock Posted April 13, 2007 Share Posted April 13, 2007 So back from hols and what do I do get stuck in with the truck Right here we go, remove handbrake/disk, remove cover and bearing support, watch for the drips.. Here's a few of the selector set up I'm using (courtesy of Filthyboy !) which IIRC is a Disco 3 selector but I'm not sure and finished! Fitting instructions are in the Tony's post in the Tech Archive Mine didn't go as per fitting instructions¦.well it did until I came to put the rear carrier in and I didn't have enough space, I had to assemble it roughly including the input gear, get it all into place, then take it apart and put it back together properly Quote Link to comment Share on other sites More sharing options...
JST Posted April 13, 2007 Share Posted April 13, 2007 excellent bit of kit that Les, you will certainly be pleased with it, so you coming to marshall then on the 5th May (Bampton).... might as well get completely back into it! You ever find that bike fork pump? Quote Link to comment Share on other sites More sharing options...
will_warne Posted April 14, 2007 Share Posted April 14, 2007 Les, nice job. FYI the gator that sits at the base of the LT230 hi-low selector is a pretty good fit for the DII selector like you've got (3 of the holes line up one's slightly off). I use one to stip muck getting into the selector for my underdrive and have just made up an ally plate which is bonded to the gator that then picks up on the mounting holes. Bad description, I know, but I'll get you a part no later. Quote Link to comment Share on other sites More sharing options...
will_warne Posted April 14, 2007 Share Posted April 14, 2007 Les, nice job. FYI the gator that sits at the base of the LT230 hi-low selector is a pretty good fit for the DII selector like you've got (3 of the holes line up one's slightly off). I use one to stip muck getting into the selector for my underdrive and have just made up an ally plate which is bonded to the gator that then picks up on the mounting holes. Bad description, I know, but I'll get you a part no later. Part no. FRC 6872 only available from LR AFAIK Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted April 14, 2007 Share Posted April 14, 2007 Does this mean you've decided to stay with the Challenge spec then Les ? Mo Quote Link to comment Share on other sites More sharing options...
