Mo Murphy Posted April 25, 2007 Share Posted April 25, 2007 Q1. Does the extension case on the back of an LT77 gearbox have a filler or does it fill from the main gearbox filler ? Q2. To reduce the fuelling (for the mot) does the full flow screw on the back of a 300 Tdi injection pump need to be screwed in or out ? Cheers Mo Quote Link to comment Share on other sites More sharing options...
Tonk Posted April 25, 2007 Share Posted April 25, 2007 it fills from the main gearbox filler Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted April 25, 2007 Share Posted April 25, 2007 and the screw needs to be wound out..... not too far or it falls on the floor and diesel gushes out of the pump* * a "friend" told me.... Quote Link to comment Share on other sites More sharing options...
GBMUD Posted April 25, 2007 Share Posted April 25, 2007 For the MOT, I would use (If I had to ) the cable tension adjuster. If backed right off (lots of slack in the cable) then only 1/4 throttle is available at full peddle travel. Remember that the rules say a car is tested "as presented". Chris Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted April 25, 2007 Author Share Posted April 25, 2007 Thank you gentlemen Mo Quote Link to comment Share on other sites More sharing options...
