wormhole Posted May 6, 2007 Share Posted May 6, 2007 Afternoon Gents, Does anyone know, is the Hi-cap pickup tub for a 110 (truck cab) the same size as for a 130 crew cab? Cheers Matt Quote Link to comment Share on other sites More sharing options...
BogMonster Posted May 6, 2007 Share Posted May 6, 2007 It is a fair bit bigger than a 130 IIRC. Maybe a foot or two longer I guess? Quote Link to comment Share on other sites More sharing options...
western Posted May 6, 2007 Share Posted May 6, 2007 110 version is 79.2 inches or 2010mm internal length 130 version is 66.75 inches or 1670mm, all other diemensions are identical. Quote Link to comment Share on other sites More sharing options...
wormhole Posted May 7, 2007 Author Share Posted May 7, 2007 Thanks for the quick responce gents - I'm just toying with the idea of changing to a (slightly) more practical crew cab and hi-cap pickup - just saw a 110 hi cap pickup tub cheap on LRO... Cheers Matt Quote Link to comment Share on other sites More sharing options...
wormhole Posted May 7, 2007 Author Share Posted May 7, 2007 never mind - double post Quote Link to comment Share on other sites More sharing options...
western Posted May 7, 2007 Share Posted May 7, 2007 on your 130's chassis you could use the full 110 hi-cap body & change the cab size to a king-cab with 2 doors, only other way to have a full 4 door cab is to strech the chassis to 150 inche wheel base & then the 110 hi-cap body would fit OK. Quote Link to comment Share on other sites More sharing options...
wormhole Posted May 7, 2007 Author Share Posted May 7, 2007 on your 130's chassis you could use the full 110 hi-cap body & change the cab size to a king-cab with 2 doors, only other way to have a full 4 door cab is to strech the chasis to 150 inche wheel base & then the 110 hi-cap body would fit OK. Even I draw the line at stretching it, I've just emailed all the breakers I can find in the mags for any prices they have to see what it'll come to - I like the crew cab idea... Cheers Quote Link to comment Share on other sites More sharing options...
