Stewart Posted May 12, 2007 Share Posted May 12, 2007 Hi, how much of a differnce does it make in fitting RR diffs in a series 3. Is it possible to make the speedo read properly? Thanks Stewart Quote Link to comment Share on other sites More sharing options...
Jon White Posted May 12, 2007 Share Posted May 12, 2007 Depends what size tyres are you running? Quote Link to comment Share on other sites More sharing options...
rtbarton Posted May 12, 2007 Share Posted May 12, 2007 Hi, how much of a differnce does it make in fitting RR diffs in a series 3. Is it possible to make the speedo read properly?Thanks Stewart Your actual speed will be 4.7/3.54 greater than the indicated speed. The odometer will read low by the same ratio. Torque at the wheels will be reduced by the same ratio, so less acceleration and more stress on the transmission. Quote Link to comment Share on other sites More sharing options...
bill van snorkle Posted May 12, 2007 Share Posted May 12, 2007 The difference is around 33% I think. Far too much for standard engines IMO. And if you have a powerfull enough engine then the combination of engine and diff ratio will prove too much for the series gearbox to cope with if you expect any degree of reliability. Bill. Quote Link to comment Share on other sites More sharing options...
Bomag Posted June 4, 2007 Share Posted June 4, 2007 Ive fitted them to my s2, with a s3 gearbox and SD1 3.5 V8, Ive got to say its much more drivable with the torque in the right place (it appeared to overrev with little movement with series diffs) I used a s3 heavy duty clutch and diesel mounts, but thats as far as Ive needed to go at the moment. Quote Link to comment Share on other sites More sharing options...
