TheBeastie Posted May 18, 2007 Share Posted May 18, 2007 Hi Was greasing prop shafts on The Beastie and ran out of grease. Daughter volunteered to get when passing Halford and has come back with a tub of Comma CV Lith-Moly Grease. Will this do for standard use greasing up UJs etc? I know it is probably a silly question but I seem to recall that different greases have different properties and not sure if this would be suited to whatever wear a UJ gets. If it isn't any use for UJs etc, is it good for any other LR maintenance or should I just go and change it. Thanks for your patience and tolerance! Best wishes Malcy Quote Link to comment Share on other sites More sharing options...
Kim Horsevad Posted May 18, 2007 Share Posted May 18, 2007 HiWas greasing prop shafts on The Beastie and ran out of grease. Daughter volunteered to get when passing Halford and has come back with a tub of Comma CV Lith-Moly Grease. Will this do for standard use greasing up UJs etc? I know it is probably a silly question but I seem to recall that different greases have different properties and not sure if this would be suited to whatever wear a UJ gets. If it isn't any use for UJs etc, is it good for any other LR maintenance or should I just go and change it. Thanks for your patience and tolerance! Best wishes Malcy It will do fine! Generally, to judge the quality of a grease for mechanical purposes place a small amount of grease on a flat steel surface and strike it with a hammer. Inspect the face of the hammer, if there still is a small amount of grease on the striking surface of both the hammer and flat surface, then the grease will also have the right properties for sticking to gears and bearings in the mechanical assembly. Quote Link to comment Share on other sites More sharing options...
western Posted May 18, 2007 Share Posted May 18, 2007 As it's meant for CV joints it'll be fine in your UJ's Quote Link to comment Share on other sites More sharing options...
TheBeastie Posted May 18, 2007 Author Share Posted May 18, 2007 Thank you Now all I need is the rain to stop since I do not fancy doing the backstroke to get underneath the car!! Best wishes Malcy Quote Link to comment Share on other sites More sharing options...
