Exmoor Beast Posted May 31, 2007 Share Posted May 31, 2007 I am replacing the downpipe on my 110 (200TDi into a TD system) as the bracket back to the block has busted once too often and I am sick of breathing exhaust fumes. To get a really good gas free seal to the turbo do I need to use any sort of sealant in the joint? Will Quote Link to comment Share on other sites More sharing options...
sgnas Posted May 31, 2007 Share Posted May 31, 2007 Exhaust putty/paste can be used when assembling a new system to ensure gas tight seal. Quote Link to comment Share on other sites More sharing options...
Exmoor Beast Posted May 31, 2007 Author Share Posted May 31, 2007 Gun Gum? or is it rubbish? Will Quote Link to comment Share on other sites More sharing options...
Les Henson Posted May 31, 2007 Share Posted May 31, 2007 I use Gun Gum every time for exhaust gas seals - it's very good stuff. Les. Quote Link to comment Share on other sites More sharing options...
Exmoor Beast Posted May 31, 2007 Author Share Posted May 31, 2007 Thanks Les, handy its the only thing I can get locally without a 40 mile drive. I am taking the angle grinder to the rear box later and chopping that out to be replaced with stainless of a bigger bore so I will use it on that as well. Full restoration of the 110 to follow Will Quote Link to comment Share on other sites More sharing options...
western Posted May 31, 2007 Share Posted May 31, 2007 Will, mines the same system, I've only had 1 down pipe bracket crack, current one is a normal mild steel down pipe, if it's aligned correctly it should be fine, [might need a thick washer between block & pipe bracket ] & it should sit tight to the block without any packing, gun gum on mine too, it's good stuff. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted May 31, 2007 Share Posted May 31, 2007 Well I actually glued your clutch on with it Ralph! Les. Quote Link to comment Share on other sites More sharing options...
western Posted May 31, 2007 Share Posted May 31, 2007 Well I actually glued your clutch on with it Ralph! Les. Well if you did, it's brill stuff, clutch is still fine, much better than the one we took out Quote Link to comment Share on other sites More sharing options...
