scottydo Posted October 12, 2005 Share Posted October 12, 2005 Im thinking of getting the side exiting exhaust that he has for sale. Is it any good? Does it make the exhaust note to loud to drive the 90 every day? Quote Link to comment Share on other sites More sharing options...
will_warne Posted October 12, 2005 Share Posted October 12, 2005 Im thinking of getting the side exiting exhaust that he has for sale.Is it any good? Does it make the exhaust note to loud to drive the 90 every day? I've made a simerlar system to his and, if you're running a diesel then you'll be fine. Quote Link to comment Share on other sites More sharing options...
Divster Posted October 13, 2005 Share Posted October 13, 2005 Im thinking of getting the side exiting exhaust that he has for sale.Is it any good? Does it make the exhaust note to loud to drive the 90 every day? You will notice a higher level of noise. However, I wouldn't say that you couldn't live with it. The exhaust is good. If you buy as a kit, spend time and effort checking and double checking your measurements, especially the exit hole. Also, well worth the time finding someone with a tig welder to weld the joints up. Quote Link to comment Share on other sites More sharing options...
muddyplugger Posted October 14, 2005 Share Posted October 14, 2005 If you buy as a kit, spend time and effort checking and double checking your measurements, especially the exit hole. I didn't know you can get them as a kit! Sounds good! I was going to use an angle grider, hack a bit off and then use some sleeves to join it back together. [Exit out of rear quarter panel behing rear wheel, though, not quite as drastic as yours!] Quote Link to comment Share on other sites More sharing options...
Divster Posted October 14, 2005 Share Posted October 14, 2005 I didn't know you can get them as a kit! Sounds good!I was going to use an angle grider, hack a bit off and then use some sleeves to join it back together. [Exit out of rear quarter panel behing rear wheel, though, not quite as drastic as yours!] At the moment I think Gwyn only supplies a kit for the exhaust to exit in front of the near side rear arch. Like so::: Quote Link to comment Share on other sites More sharing options...
will_warne Posted October 14, 2005 Share Posted October 14, 2005 I didn't know you can get them as a kit! Sounds good!I was going to use an angle grider, hack a bit off and then use some sleeves to join it back together. [Exit out of rear quarter panel behing rear wheel, though, not quite as drastic as yours!] Muddyplugger, I spend a fair bit of time up in you're neck of the woods. If you'd like to look at my setup you're very welcome. Give me a couple of weeks, though, as I need to weld on a couple of mounts that are currently jubilee cliped on Quote Link to comment Share on other sites More sharing options...
JST Posted October 14, 2005 Share Posted October 14, 2005 couple of weeks best of leaving it a couple of months before you contact Will!!!!! Scotty you still thinking of doing your suspension at mine at some point? are you going to the rtv next sun still? if so will see you there. Quote Link to comment Share on other sites More sharing options...
muddyplugger Posted October 14, 2005 Share Posted October 14, 2005 Is Will that reliable then? I'm always up for ideas and advice, GREAT! mind you I love the colour of your 90 Divster! What colour is that???? Is it bonatti grey? Quote Link to comment Share on other sites More sharing options...
scottydo Posted October 15, 2005 Author Share Posted October 15, 2005 James my funds dropped a little after having to replace the fuel pump 4 injectors and 2 heater plugs. but should still get the suspension I just have to see what the bank balance is like next week. Yep shall be going the rtv next week not competing though. Quote Link to comment Share on other sites More sharing options...
will_warne Posted October 15, 2005 Share Posted October 15, 2005 couple of weeksbest of leaving it a couple of months before you contact Will!!!!! Scotty you still thinking of doing your suspension at mine at some point? are you going to the rtv next sun still? if so will see you there. Haha, the problem at the moment is I've got tooo many jobs to do (again). Its only a 30 minute welding job but as it works at the moment its right at the bottom of the job list. I did mean weeks, though. Slip of the keys.... Quote Link to comment Share on other sites More sharing options...
Divster Posted October 19, 2005 Share Posted October 19, 2005 Is Will that reliable then? I'm always up for ideas and advice, GREAT! mind you I love the colour of your 90 Divster! What colour is that???? Is it bonatti grey? Spent ages matching the colour for the new panels I fitted. Actually turned out to be mid pennine grey. Quote Link to comment Share on other sites More sharing options...
