bazza Posted July 2, 2007 Share Posted July 2, 2007 Any ideas what this sensor is for? fitted to the rear of a Borg Warner Transfer case 1993 RRC. carp picture i know! Quote Link to comment Share on other sites More sharing options...
geoffbeaumont Posted July 2, 2007 Share Posted July 2, 2007 Any ideas what this sensor is for? fitted to the rear of a Borg Warner Transfer case 1993 RRC. carp picture i know! That'll be the road speed sensor (for the speedo - also monitored by the ECU, IIRC), I think. Can't remember exactly where it is on the BW, but I can't think of any other switches or sensors on it (there's no diff lock, so no diff lock light switch). Quote Link to comment Share on other sites More sharing options...
istruggle2gate11 Posted July 2, 2007 Share Posted July 2, 2007 IIRC its a temp sensor? Quote Link to comment Share on other sites More sharing options...
bazza Posted July 3, 2007 Author Share Posted July 3, 2007 Whats IIRC? The speedo is electromic but thats run from a short speedo cable with some sort of transponder bolted to the chassis. Cheers Baz Quote Link to comment Share on other sites More sharing options...
bishbosh Posted July 3, 2007 Share Posted July 3, 2007 IIRC means If I recall correctly. The sensor is a temperature sender. Quote Link to comment Share on other sites More sharing options...
bazza Posted July 3, 2007 Author Share Posted July 3, 2007 IIRC means If I recall correctly.The sensor is a temperature sender. Ah, i see said the blind man to the deaf dog!! Thanks for all your help people Baz Quote Link to comment Share on other sites More sharing options...
