selectcase Posted July 4, 2007 Share Posted July 4, 2007 I Just need to check that I have the wiring right on this alternator as it seems almost too simple which usually means something is wrong? Its a Denso A127-65 the terminal B+ goes to the battery positive (thick brown wire) is it worth putting a fusable link in this? the terminal D+ goes to the warning light (brown with yellow light) I dont know where the white wire coming from the terminal marked W goes? perhaps a rev counter or something? thanks will Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted July 4, 2007 Share Posted July 4, 2007 Yup, the size of the stud terminals make it pretty easy to work out which wire goes where. Being a pedant, B+ normally goes to the starter motor, which of course then goes to the battery. No it's not worth putting a fusable link in for the alternator. The W terminal is for a rev counter. If you want one, make sure you buy one for alternator/diesel feed, as they're different to petrol engine rev counters, some are switchable to run off both. Quote Link to comment Share on other sites More sharing options...
selectcase Posted July 4, 2007 Author Share Posted July 4, 2007 Thanks for that - I can get on with some wiring when the rain stops Quote Link to comment Share on other sites More sharing options...
02GF74 Posted July 4, 2007 Share Posted July 4, 2007 hey, LML, if you are goimng top be a pedant, get it right - fat wire goes to starter motor solenoid Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted July 4, 2007 Share Posted July 4, 2007 Ok, Ok, "The alternator connects to the high current connection (the big one) on the starter motor solenoid, to which is also attached the cable from the positive terminal on the battery." hey, LML, if you are goimng top be a pedant, get it right Psst, it's "going to be" , y'know, if I'm going to be a pendant. Quote Link to comment Share on other sites More sharing options...
