tpk241 Posted July 6, 2007 Share Posted July 6, 2007 Hi All, I am wondering about what is involved in an on-board air system using a Air con compressor (300TDI Disco) Are any of you running a setup from your air-con compressor ? I am considering stripping mine out for bigger intercooler and recycling the electric fans for my rad. If anyone can help with kit needed and best ways to utilise the compressor please let me know Thanks TPK Quote Link to comment Share on other sites More sharing options...
Mark Posted July 6, 2007 Share Posted July 6, 2007 Have a look in the Tech archive - there are at least 2 (possibly 3) wirteups of other people's take on this.. enjoy Mark Quote Link to comment Share on other sites More sharing options...
tpk241 Posted July 6, 2007 Author Share Posted July 6, 2007 Have a look in the Tech archive - there are at least 2 (possibly 3) wirteups of other people's take on this..enjoy Mark Excellent, thanks Mark Quote Link to comment Share on other sites More sharing options...
istruggle2gate11 Posted July 6, 2007 Share Posted July 6, 2007 Excellent, thanks Mark 2nd best mod Ive done Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted July 6, 2007 Share Posted July 6, 2007 And the best was? Looking to start this on mine shortly. What fitting did you use to go from the compressor to the pipework of the rest of the system. As far as I can see the hose from the air con compressor has some strange threads which do not appear to be compatable with copper, hydraulic or water fittings. Any inside tips? Quote Link to comment Share on other sites More sharing options...
wizard Posted July 6, 2007 Share Posted July 6, 2007 And the best was?Looking to start this on mine shortly. What fitting did you use to go from the compressor to the pipework of the rest of the system. As far as I can see the hose from the air con compressor has some strange threads which do not appear to be compatable with copper, hydraulic or water fittings. Any inside tips? When i put my on board air system together i tapped the original fitting to 1/4 bsp and used standard pneumatic fittings.The air coming out of the compressor is very hot so any fitting with plastic on will melt. The connection onto the compressor needs to be a brass or stainless fitting with a lenght of copper pipe leading to an air cooler or straight down to a tank. All the fittings after this can be standards pneumatic ones. wizard Quote Link to comment Share on other sites More sharing options...
istruggle2gate11 Posted July 6, 2007 Share Posted July 6, 2007 And the best was?Looking to start this on mine shortly. What fitting did you use to go from the compressor to the pipework of the rest of the system. As far as I can see the hose from the air con compressor has some strange threads which do not appear to be compatable with copper, hydraulic or water fittings. Any inside tips? The best was Megasquirt and spark. I used my local hydraulics man, he had every fitting required and we used hydraulic pipe ø1" from front to rear. Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted July 7, 2007 Share Posted July 7, 2007 The best was Megasquirt and spark.I used my local hydraulics man, he had every fitting required and we used hydraulic pipe ø1" from front to rear. That must mean that since i have a diesel it will be the best mod I do We have a good hydraulic supplier in town, i'll give em a shout. Also found this link which is quite useful http://www.ackerdackerly.com/saccpv1.pdf Quote Link to comment Share on other sites More sharing options...
