simonr Posted November 12, 2005 Share Posted November 12, 2005 Si,I have measured the hole spacing on the back plate and the holes are 83mm apart vertically and horizontally which gives a PCD of about 117mm. Is this similar to your mounting bracket. Phil Thanks Phil, I've been working wih a chap to produce something for his Range Rover. He's done most of the work including fabricating a new back plate. Yesterday he phoned to say he was close to fitting it but it requires a fairly different setup altogether. If it works, I'll get a few laser cut. Si Quote Link to comment Share on other sites More sharing options...
Wattle Posted November 12, 2005 Author Share Posted November 12, 2005 Thanks Phil,I've been working wih a chap to produce something for his Range Rover. He's done most of the work including fabricating a new back plate. Yesterday he phoned to say he was close to fitting it but it requires a fairly different setup altogether. If it works, I'll get a few laser cut. Si Si, Some Range Rovers with the LT95 box have a really small hand brake drum fitted, mine isn't that small. Is the setup the other chap is working on for the small drum.? Phil Quote Link to comment Share on other sites More sharing options...
simonr Posted November 12, 2005 Share Posted November 12, 2005 Si,Some Range Rovers with the LT95 box have a really small hand brake drum fitted, mine isn't that small. Is the setup the other chap is working on for the small drum.? Phil Yup. It is the gearbox that is all one casting, including the transfer box. It has just struck me that perhaps the speedo housings are interchangable, which may mean that a standard drum (or a certain disk handbrake) would fit! Sounds like you might be in luck! PCD is 119mm and the hole in the middle is 98mm diameter. Si Quote Link to comment Share on other sites More sharing options...
Wattle Posted November 12, 2005 Author Share Posted November 12, 2005 Si, I have sent you a PM. Phil Quote Link to comment Share on other sites More sharing options...
s2hotdog Posted November 12, 2005 Share Posted November 12, 2005 Simon so have I...................................... sent you a pm Steve Quote Link to comment Share on other sites More sharing options...
simonr Posted November 12, 2005 Share Posted November 12, 2005 Simon so have I...................................... sent you a pmSteve Thanks Chaps! Si Quote Link to comment Share on other sites More sharing options...
