Gromit Posted August 10, 2007 Share Posted August 10, 2007 I can't seem to find this in my parts cat. I'm looking for the lock washer you bend over the nut that holds the drop arm on. Mine, despite the lock washer, works loose every once in a while, so I thought I'd replace the washer, clean it up and maybe loctite it too. oh, this is the 4 bolt box. anyone see it in RAVE or microcat? Quote Link to comment Share on other sites More sharing options...
western Posted August 10, 2007 Share Posted August 10, 2007 you won't find any part numbers in RAVE cos it's the workshop manual. anyway 600265 for 48mm shaft ( & also for the Adwest manual steering box) or STC874 for 60mm shaft both for Adwest 4 bolt power steering boxes. EPC triumph's again Quote Link to comment Share on other sites More sharing options...
Gromit Posted August 10, 2007 Author Share Posted August 10, 2007 you won't find any part numbers in RAVE cos it's the workshop manual.anyway 600265 for 48mm shaft ( & also for the Adwest manual steering box) or STC874 for 60mm shaft both for Adwest 4 bolt power steering boxes. EPC triumph's again Thanks Ralph. The threaded portion of the shaft is 22mm, so what size shaft is that? I can see 600265 in my catalog, but it only has 1 tab. What's fitted to my truck has 3 tabs, 2 that bend up either side of the drop arm, and 1 down over the nut. Quote Link to comment Share on other sites More sharing options...
western Posted August 10, 2007 Share Posted August 10, 2007 the washer should just fit on the end of the shaft above the threaded section IIRC, sounds like a previous attempt has bent the washer itself down the sides of the droparm. or you need the AEU4025 washer for the 6 bolt Gemmer box. Quote Link to comment Share on other sites More sharing options...
Gromit Posted August 10, 2007 Author Share Posted August 10, 2007 Hmm, now more confused. Here's 3000 words: Maybe I should just get 2 nuts instead. Quote Link to comment Share on other sites More sharing options...
western Posted August 10, 2007 Share Posted August 10, 2007 the section folded onto the side of the nut is part of the washers main diameter, maybe someone has fitted a Series lock washer. my paper parts book says 600265 too Quote Link to comment Share on other sites More sharing options...
Phoenix_chris Posted August 11, 2007 Share Posted August 11, 2007 hmm, thats odd.. Microcat just give 600265 for all adwets and AEU4025 for gemmer.. Possibly someone has use one of 'its on the floor, looks like it'll fit' washers ...that washer should be bent over the nut surely, hence the lock tab name.. or have i just got bad eyesight..! Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted August 11, 2007 Share Posted August 11, 2007 On my 3 bolt box I have that washer thing. 2 tabs bent around the drop arm and then a section bent along the flat of the nut. HTH Quote Link to comment Share on other sites More sharing options...
western Posted August 11, 2007 Share Posted August 11, 2007 Just note guys, the parts cat diagrams are generic & don't represent the actual part, so even though the diagram shws 1 tab the real thing may well have 2 or 3 tabs. But you all knew that anyway, or at least I hope you all do. Quote Link to comment Share on other sites More sharing options...
