ltwt1981 Posted October 25, 2005 Share Posted October 25, 2005 Here are a couple of pics as the ltwt is now. I get 22 inches of articulation at present with parabolics and +2" shocks front, standard heavy duty rear. Got some longer shocks for the back at Sodbury so on they go. I have 5" shackles on the rear and standard on the front, if I put longer shackles on when do I get propshaft problems and is it worth the trade off. What are the longest I can use, I'll try 6" on the rear and add an inch to the front first to see what effect that has. As you can see it gets 16" front lift with the opposite rear on two 4" blocks, the right front is about 2" off in these pics. Quote Link to comment Share on other sites More sharing options...
Tonk Posted October 25, 2005 Share Posted October 25, 2005 is that an axle strap i can see on the rear? the amount of droop in the suspension will be dictated by the prop angle, binding yokes etc. whilst doing suspension mods keep in mind wot u may or may not do with transmission lengths in the future Quote Link to comment Share on other sites More sharing options...
ltwt1981 Posted October 25, 2005 Author Share Posted October 25, 2005 Yes straps still on but lengthened, what can I realistically achieve, another 2" at the rear and probably a bit at the front, 26-28" maybe? Quote Link to comment Share on other sites More sharing options...
Tonk Posted October 25, 2005 Share Posted October 25, 2005 i binned the straps (as have most others). i've never measured amount of travel so cant comment. but have remade bottom mounts and shifted top mounts, got it to the pont of having a fair bit of articulation which i am happy with and called it job done. i do believe u can have too much Quote Link to comment Share on other sites More sharing options...
ltwt1981 Posted October 25, 2005 Author Share Posted October 25, 2005 Anyone comment on what is standard on leaf sprung so I have something to compare with. Quote Link to comment Share on other sites More sharing options...
Jon White Posted October 25, 2005 Share Posted October 25, 2005 No idea whats standard but lose the axle straps! I'm running 1 tonne shackles front and rear, with parabolics all rount and pro-comp shocks. You'll get away with the standard rear propshaft, but the front end needs more attention. Take a grinder to the spring seats on the front axle to correct the castor angle. You can use correction wedges, but they're nasty and keep working loose. You'll then find that the standard series front prop is not short, but also the sliding joint is too short, and the front prop hits the x-member. You need to scallop the x-member if you havnt already and make up a prop shaft to suit by cutting down one from a coiler (mines a cut down 4 speed rangie front prop) as the sliders are longer on the coilers. I've also re-mounted my shocks higher for more ground clearance. Ok.......getting very approximate here - with my offside front wheel on top of an approximately 3 foot high bank, the offside rear wheel ends up about 1" off the ground on an otherwise flat surface (the local school car park funnily enough!) HTH Jon Quote Link to comment Share on other sites More sharing options...
Tonk Posted October 25, 2005 Share Posted October 25, 2005 Ok.......getting very approximate here - with my offside front wheel on top of an approximately 3 foot high bank, the offside rear wheel ends up about 1" off the ground on an otherwise flat surface (the local school car park funnily enough!)HTH Jon why do i get the feeling i'll be usin my winch to put u back on your wheels again before long Quote Link to comment Share on other sites More sharing options...
Jon White Posted October 25, 2005 Share Posted October 25, 2005 I told you I "nearly" rolled it.......... Got to fix it first anyroad..... Quote Link to comment Share on other sites More sharing options...
Tonk Posted October 25, 2005 Share Posted October 25, 2005 Got to fix it first anyroad..... minivin, any news on bits? Quote Link to comment Share on other sites More sharing options...
minivin Posted October 25, 2005 Share Posted October 25, 2005 minivin,any news on bits? which bits that? LT77 or the clonking rear prop due to articulation Quote Link to comment Share on other sites More sharing options...
Tonk Posted October 25, 2005 Share Posted October 25, 2005 the input gears? Quote Link to comment Share on other sites More sharing options...
ltwt1981 Posted October 25, 2005 Author Share Posted October 25, 2005 Thanks people, I'm not sure I want to go to 36" as like Tonk i would then think of rolling it, but 24-30" seems to be where I would like to be. Nige tells me you've modded the spring hangers as well Jon Nige T Quote Link to comment Share on other sites More sharing options...
Tonk Posted October 25, 2005 Share Posted October 25, 2005 remake the bottom spring plates so the shock doesn't protrude downwards which gains u about 30mm extra drop without havin to buy new shocks Quote Link to comment Share on other sites More sharing options...
Jon White Posted October 25, 2005 Share Posted October 25, 2005 Yep - remade with a flat plate, with the bottom shock eye then relocated to above the flat plate. Gives you alot more ground clearance. You may then need to move the top mounts up aswell else the shock will bind on full bump. I've done this on the front, may in future do the rear top mounts also, need to check clearances on full bump at some point. Also bear in mind for more articulation you'll need to either fit longer front brake hoses or make some dropper brackets else the hoses will be too short. Rear one is fine as standard. Jon Quote Link to comment Share on other sites More sharing options...
ltwt1981 Posted October 25, 2005 Author Share Posted October 25, 2005 Got some nice stainless hoses so all right there. But how long can I take the shackles at the rear, it hits the underside of the tub boxes at the moment so another inch may help. Quote Link to comment Share on other sites More sharing options...
Jon White Posted October 25, 2005 Share Posted October 25, 2005 Ah - I cut out the tops of the rear boxes and raised them up by about 2". IIRC the rear one tonne shackels are 6". I wouldnt be inclined to go much higher than this. Jon Quote Link to comment Share on other sites More sharing options...
Tonk Posted October 25, 2005 Share Posted October 25, 2005 cut your tub boxes up by 50mm, most people do. wot size tyres u running? on full drop out r u bottoming out your shocks? wot r u tryin to achieve? drop out or a really high truck? Quote Link to comment Share on other sites More sharing options...
ltwt1981 Posted October 25, 2005 Author Share Posted October 25, 2005 Tyres 235*85*16 Grizzlys. Trying to get better off road ability, height can be an advantage, clearance or a disadvantage, rolls over, so a happy medium is the answer. Got to have clearance and room to move the wheels about, but want COG low to prevent roll over. You two seem to be the only leaf sprung people doing this sort of thing so will have a good look at your trucks at the HBRO MWMC in Feb. Quote Link to comment Share on other sites More sharing options...
Tonk Posted October 25, 2005 Share Posted October 25, 2005 You two seem to be the only leaf sprung people doing this sort of thing so will have a good look at your trucks at the HBRO MWMC in Feb. better look at it before the event, cos after it will be covered. a slightly bigger tyre will give u better clearance underneath, thus necessitating the cutting of the rear boxes. u can raise the body as much as u like but they'll still be the same clearance under your axles. higher u go then increasing the offset of the rims u use is a way of keeping it more stable. Quote Link to comment Share on other sites More sharing options...
ltwt1981 Posted October 25, 2005 Author Share Posted October 25, 2005 I will as I'm scrutineeering the trucks. Quote Link to comment Share on other sites More sharing options...
Tonk Posted October 25, 2005 Share Posted October 25, 2005 I will as I'm scrutineeering the trucks. ahem.....errrrr ............ummmm........ wot do u drink? Quote Link to comment Share on other sites More sharing options...
ltwt1981 Posted October 25, 2005 Author Share Posted October 25, 2005 Normally bitter but in the mornings tea, joking aside its not normally a problem at these events, Nige and I like to have a good fun day, no hassle or grief, so prepare well and all will be well. When I started scrutineering I was told we are not here to stop people competing but to overcome any issues of safety. In the last eight years of motor racing I think I have only stopped one car racing and that one you could poke your fingers through the roll cage. The owner said but its a 1968 car with the original cage and I want to keep it original, answer, put it in a museum then. We normally will tell people they have a problem, go away and fix it, if it cant be fixed, we will unless critical as above, let them play. However someone has to define critical and at MWMC that is mine and Niges role. Quote Link to comment Share on other sites More sharing options...
Tonk Posted October 25, 2005 Share Posted October 25, 2005 i quite agree, i doubt u'll find anything wrong with mine (thats not a challenge BTW ) Quote Link to comment Share on other sites More sharing options...
ltwt1981 Posted October 25, 2005 Author Share Posted October 25, 2005 Its also about common courtesy, say good morning with a smile, not whats this pile then, and you're already half way there, I've seen it at high profile events and you often never see the scrut again after that. If you are nice to the competitor they are normally nice back and you get any minor bits fixed easily then. Mind you there is always an exception, especially karts, so I don't do them at all. Quote Link to comment Share on other sites More sharing options...
Tonk Posted October 25, 2005 Share Posted October 25, 2005 so do i take it u'll be marshallin on the day too? hbro is normally one marshal assigned to a team......... Quote Link to comment Share on other sites More sharing options...
